I am using Extensis Studios Flexi Layouts Pro to desin my page. When I add the Google Map the first time it is fine, but if I need to edit my file in Flexi Layouts and save the map disapears and several lines of code are added to my file. I ahev atta
Thread begun 8/01/2013 8:28 pm by luisc257726 | Last modified 8/02/2013 8:20 am by Jason Byrnes | 2065 views | 1 replies |
luisc257726
I am using Extensis Studios Flexi Layouts Pro to desin my page. When I add the Google Map the first time it is fine, but if I need to edit my file in Flexi Layouts and save the map disapears and several lines of code are added to my file. I ahev attached t
I can add using the Google maps API and this does not happen, but if I use the extension it does.
Thank you,
Luis
It sounds like a probelm with the Extensis Studios extension and the way it inspects code on the page.
looking at the code you attached, it is breaking the script tag that attaches the map JS file:
for example:
/*wagmp*/
<style style="display:none" data-xeditor="ss" data-xeditor-pi-id="<style style="display:none" data-xeditor="ss" data-xeditor-pi-id="<?php include("webassist/google_javascript/wagmp_map_8.php"); ?>" data-xeditor-translated="true"><?php include("webassist/google_javascript/wagmp_map_8.php"); ?></style>" data-xeditor-translated="true"><style style="display:none" data-xeditor="ss" data-xeditor-pi-id="<?php include("webassist/google_javascript/wagmp_map_8.php"); ?>" data-xeditor-translated="true"><?php include("webassist/google_javascript/wagmp_map_8.php"); ?></style></style>
</script>
that should be:
/*wagmp*/
</script>
a posible work around would be to create a separate php file for the map, then use framework builder plugins to plug the map into the main page. this way the map code is separated from the page and should be changed when using the Extensis Studios extension to edit the layout.
