Content division is pushed to end of Navigation Menu (far right)
Thread begun 8/01/2013 7:05 pm by evansg7124312885 | Last modified 8/26/2013 6:57 pm by evansg7124312885 | 1870 views | 2 replies |
evansg7124312885
Built a site with SIte Sculptor, made a few customizations to the base template as far as pages and colors. I used preview all the way through and everything appeared OK during the use of the GUI. After the pages were created, the content and left side bar were pushed right. Everything under the Nav Menu is empty, the division for content is what appears to be setting above bottom of the navigation bar marker. It appears to be an issue of placement of elements, but I am not sure where I should go to correct this. I have attached the Index and Template files. Any help is appreciated,
Gary Evans
Please post a link where i can see the problem.
it is fairly impossible to troubleshoot design issues without being able to see them in the browser.
evansg7124312885
Sorry for delay in answer
I never did push to remote with this issue, only present in the localhost environment. I will keep this in mind if similar issue appears again.
I was able to correct this problem by using return/enter shifting everything down one line. This did add a little white space, but not a big enough problem to pursue further. This is a personal site that I work on when time allows, if problem shows up again, I will push to remote and let you know.
Thanks for response,
