Fed Ex "No Packages to Ship" issue
Thread begun 8/01/2013 6:57 am by Jared Lui | Last modified 8/05/2013 3:28 pm by Ray Borduin | 3692 views | 8 replies |
Jared Lui
Hey Jason, I'm revisiting this issue after a layoff. I started from scratch and used the new(est) power store 4.5.3 I believe it is.
I am still getting the No Packages to Ship error as seen below. I have weights 1 pound and above on every item and have tested out on several items. I have verified that I am hitting the correct production server
$FedEx_Server = "https://ws.fedex.com:443/web-services";
in both the
WA_eCart_FedEx_PHP
and
WA_eCart_FedEx_v10_PHP
files and Fed Ex confirms that they are seeing all of the correct order info on their production server. I'm not sure what to check next.
One thing I have noted and am not sure this has anything to do with it. The database stores the weight as X.XX (float 12,2) not sure if this is worth mentioning.
NOTE: I changed some of the characters in the string below in case there is sensitive info in it.
["WA_Store_Cart_FedEx_Success"]=> bool(false) ["WA_Store_Cart_FedEx_ResponseCode"]=> int(0) ["WA_Store_Cart_FedEx_Quote"]=> int(0) ["WA_Store_Cart_FedEx_ErrorCode"]=> int(0) ["WA_Store_Cart_FedEx_ErrorDescription"]=> string(19) "No Packages to Ship" ["WA_Store_Cart_FedEx_FullRequest"]=> string(2493) " Rfi3d3L4DmFdVkkG UeRVlYh0SiG6BUXdPzTUaVCi6 176493259105279986 crs1000 2013-08-01T08:25:41-05:00FEDEX_GROUNDYOUR_PACKAGING CA93003COUS0 TX76120COUS0 CA93003COUS0 SENDERUS ACCOUNT1 1 1 1 LB 2 " ["WA_Store_Cart_FedEx_FullResponse"]=> string(0) "" }
Jared Lui
See private reply.
Jared Lui
See private message
I Updated the WA_eCart_FedEx_v10_PHP.php file to correct the problem.
Jared Lui
What was the issue with the file?
fed ex has made some updates so i needed to edit the references to some of the values in the return from them.
Jared Lui
Do we have a list of these changes or will there be a patch soon? Just wondering as I'll have more Fed Ex clients soon.
Thanks!
We'll have the updates in the next eCart release in Sept. In the mean time just use the fixed file when necessary.
