Update Record and Update Multiple Records together
Thread begun 7/31/2013 1:18 pm by AArc29001415 | Last modified 8/01/2013 9:40 am by AArc29001415 | 2018 views | 5 replies |
AArc29001415
Hi, I have a single form that the user fills out, but there are also repeat regions within that form... ie:
Address: On a Street
***** Repeat Region *****
Friends with:
Stephen
Joe
Peter
***** End Repeat Region *****
Contact Number: 12345678
Submit
Is it possible to have this update all within one form and submit button, and if so, how?
Yes, that can be done.
add the Multiple record update behavior t your page, just make sure that the regular update behavior does not redirect to another page so that the multi update behavior can trigger.
AArc29001415
I'll give it a go... I had tried that before and it didn't work... but I've just updated my behaviours, so will try again... hopefully it works this time :)
AArc29001415
Hi, I tried this again and it's not working. It will work with the single update behaviour, although the page does need refreshed to display the update.
the multip update uses the WADA_RepeatID_garage_fitter_id looped hidden element to determine which records should get updated:
<input type="hidden" name="WADA_RepeatID_garage_fitter_id_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_garage_fitter_id_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_fitter["garage_fitter_id"]; ?>" />
the value for that element uses the garage_fitter_id column of the fitter recordset:
the select statement for the recordset:
SELECT garage_id, garage_fitter, garage_fitter_parts, garage_fitter_comments, user_first, user_last FROM....
does not include the garage_fitter_id column. this cause the hidden element to be blank, so it cannot pass the ID for the record to update. edit the recordset to include the garage_fitter_id column in the select statement.
as for the page needing to be refreshed, this is due to code order.
the recordset that populates the page comes before the update record code. this means the recordset is created, then the database is updated so it shows the old content. rearrange the code so the update happens before the recordsets are created, this will allow yo to see the update without having to refresh.
AArc29001415
Thank you... it's always something really simple that tiredness makes you miss. This worked a treat.
Cheers
