Databridge and Validation Toolkit
Thread begun 7/25/2013 6:36 am by Brett Atkin | Last modified 7/25/2013 2:47 pm by Brett Atkin | 2766 views | 4 replies |
Brett Atkin
Recently installed Data Bridge. It replaced the Validation Toolkit extension. There doesn't appear to be any way to update existing sites that use the Validation Toolkit. It looks like I have to remove the existing validation and start over.
Is this correct?
The Existing Server Validation behavior should be available on the Server Behaviors panel. You should be able to open the server behaviors panel and double click the server validation behavior to edit it.
Brett Atkin
I'm referring to the client side (javascript) validation.
Ahhh, Data Bridge does not include client side validation. it was replaced with the Dreamweaver Spry validation.
if you have a previous dreamweaver version, you could install the older validation toolkit in that version to be able to edit the client validation.
or another option would be to create a new system user, and install the older validation toolkit under that user, and login under that user to edit client side validation.
Brett Atkin
I will try the new system user suggestion.
