Issue with sessions and SSL
Thread begun 7/19/2013 12:10 pm by tn228553 | Last modified 7/19/2013 1:21 pm by Jason Byrnes | 1568 views | 3 replies |
tn228553
The following pages uses sessions to make sure the user is logged in (SecurityAssist) and then a record set to populate form data and finally DataAssist to insert a record into a table. This works fantastic on a regular http:// URL but when I reference the URL using HTTPS, peform an insert and then the script access the $insertGoTo portion of the script (it returns to itself to enter another record) it totally freezes up and timeout. I get a 500 Internal Server Error and when I dig down into the PHP error log it simply says: [19-Jul-2013 12:58:32 America/New_York] PHP Fatal error: Maximum execution time of 30 seconds exceeded in C:\Program Files\Apache Software Foundation\Apache2.2\htdocs\htmobile\tech_hca_parts.php on line 4 with Line 4 being the closing bracket for session_start function. That is the extent of what I can find. Any ideas? Attached is the file.
sounds like there is an issue on the SSL Side with setting session variables.
use the attached Session test page to ensure that the server can set sessions, if the test fails, you will need to contact the host to have them investigate.
tn228553
No Luck
Sessions look good, occasionally I actually get the page back if it does not timeout first. The 500 error is the timeout. Do you see anything in the code that could possibly cause a problem?
try changing:
if (!isset($_SESSION)) {
session_start();
@session_start();
