Problem with Dreamweaver CS3 After Upgrading Webassist Extensions
Thread begun 8/15/2009 1:22 pm by shadow329043 | Last modified 8/17/2009 4:33 pm by Jason Byrnes | 3325 views | 3 replies |
shadow329043
I just finished upgrading some of my Webassist Extensions - now I cannot add a new page to my site. I get the following error message when I click File -> New
"The following Javascript errors occurred: Unable to open script file "C:\program files (x86)\adobe\adobe dreamweaver cs3\configuration\shared\webassist\library\wa_preview.js (error 3)
I went to the location and the webassist and the webassist\library subdirectories do not exist.
I upgraded the following extensions - SiteAssist pro - Css Sculptor - Css Menu Writer - Surveyor - DataAssist. I deleted the winfilecache.dat file that was mentioned under installation issues with no results. I also unstalled the old extensions before updating to the new ones. I would hate to have to uninstall everything and reinstall it but if that is the only solution, I would do it.
I am using my laptop, running Windows Vista with Dreamweaver CS3 - can anyone shed any light on this problem?
Does the wa_preview.js file exist if you browse to:
C:\Users\<your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\Library\
Where <your User Name> is the name you use to log into windows.
If the file exists at that location, in Dreamweaver, go to window -> Workspace layouts -> Reset '<Layout Name>'. where <Layout Name> is name of your workspace layout. Then restart Dreamweaver.
shadow329043
No - the WA_Preview.js file do not exist at the location mentioned
Here is a copy of that file. Please copy it to the location mentioned.
