upload files
Thread begun 7/11/2013 12:53 pm by debbie295402 | Last modified 7/12/2013 8:35 am by debbie295402 | 1587 views | 4 replies |
debbie295402
upload files
how does a user upload files from their computer in PowerCMS?
If it is an image, click the image button in the toolbar, then click the Browser Server button to open the file manager, in the files manager, they will be able to upload a new image.
for another file type, use the link toolbar option. This will also have a browse server button to open the file manager.
debbie295402
As an update, I changed browsers from IE to Chrome, and all features are present. Apparently the CMS doesn't work completely in IE10. Unfortunately, that's what most of my clients use.
the KFM File manager is not updated to support IE 10, you can force it to use the IE 9 rendering engine by editing the "webasssist/kfm/index.php" file, just after the opening <head> tag, add the following code:
<meta http-equiv="x-ua-compatible" content="IE=9" >
if you are using an older version of Power CMS< it may have CKEditor 3 which does not work in IE 10. You can manually update the CKEditor version:
in the webassist/ folder, rename the ckeditor folder to ckeditor_bak
On this page:
http://ckeditor.com/download
click the button to launch CK Builder. Select to use the Full Preset, and the Kama Skin.
Copy the downloaded CKEditor folder to the webassist folder in your site.
from the ckeditor_back folder, copy the following three files:
ckeditor.php
ckeditor-php4.php
ckeditor-php5.php
and paste them in the new ckeditor folder.
you will need to clear the browsers cache to see the updates take effect.
debbie295402
Thanks!
