While executing timer JS error, trying to create results page in Databridge
Thread begun 7/10/2013 5:08 pm by YellowCircleWeb | Last modified 7/18/2013 9:23 am by Jason Byrnes | 4474 views | 11 replies |
YellowCircleWeb
Everything was working fine then all of a sudden I'm getting an error when I try to create results pages using Databridge. I'm running DWCS6 on Windows 8 64. I've cleared the cache twice to try and resolve it,but no dice.
I've attached a screenshot with the full error message shown. Can anyone help? I've looked through other posts but they aren't the same as this problem
That looks lime an install order issue.
try uninstalling data bridge, then reinstalling it.
YellowCircleWeb
I've tried that earlier, no dice. It seems to only happen when I apply a filter and sort to a recordset through the DataAssist pages creation.
I am not able to reproduce the error. Please provide a copy of the table structure you are using and the settings you are using in the wizard to reproduce the error.
also, what version of data Bridge do you have installed?
What other extensions, including version numbers are installed?
YellowCircleWeb
Sorted, but a possible bug found in the CC extensions
Jason,
I removed all the extensions and reinstalled them. I have both Dreamweaver CC and CS6 installed on the same machine. I have managed to get the solution working in CS6 and now my search and results pages are fine so that's good. However, I have discovered a serious bug in the CC version of the DataAssist extension.
I was retrieving records from a view I created in mySQL. When attempting this via CC the two connection script files that the youTube video you have posted on your site mentions that need to be copied over into the connections folder for the site are deleted, and so the DataAssist wizard always says no tables found. This only seems to happen when trying to retrieve records from a view, not from a standard table. I use views a lot so for the time being I will stick with CS6.
P.S the extensions took almost 3 hours to install in CC extension manager, whereas in the CS6 extension manager they took less than 5 minutes.
here is an updated copy of 2 files that should go in the users configuration to correct the problem.??for help finding the configuration folder, see the following tutorial:?http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95??from there, the attached files should be copied to:?/shared/webassist/libary/WA_Databases.js?shared/webassist/PowerCMS/PowerCMS_Shared.js
YellowCircleWeb
I copied the files to the locations you suggested. It didn't fix the issue in Dreamweaver CC and now when I try and run DataBridge in CS6 I get an error - see attached screen shot. I've also deleted the cache file, that didn't fix the error in CS6.
*EDIT* - I've got the CS6 version working again now, the CC version still has the same no tables found problem though. I'm connecting to the same database/site in both versions of DW.
Originally Said By: YellowCircleWeb
YellowCircleWeb
private message left
