WA Alternating Styles Server Behavior in Repeating Table
Thread begun 6/13/2013 3:25 pm by Paul | Last modified 6/20/2013 1:22 pm by Paul | 6150 views | 20 replies |
Paul
I have, with Jason's assistance, created two repeating tables on a page that shows all the records in 3 columns. I placed the first one in a Tabbed Panel DW Extension from another vendor. The first panel works nicely. The second panel is empty. Not sure why. If I remove the repeating table code and just put in static text, it works...just not with the repeating table.
There is an even and odd row css style I've attached and it works on the first panel, but I can't tell on the second.
I am getting a red exclamation mark on Server Behavior error which refers to the WA Alternating Styles 2. Double clicking the behavior doesn't do anything.
Here's the code and I've attached the page.
Appreciate any help.
//WA Alternating Class
$WARRT_AltClass2 = new WA_AltClassIterator(explode("|", "defaultodd|defaulteven"));
I would need to see this in the browser to be able to troubleshoot.
please upload this to the live server and include a link.
Paul
Hey Jason,
Just redid the connections and uploaded. Here is the link: http://www.centurymachinery.com/default.php
Thanks...
you are using the same recordset in both repeat regions.
the recordset needs to be reset to line 1.
place your cursor after the first repeat region, then go to the server behaivors panel and click the plus button
Select WebAssist -> Dynamic WebCharts -> Reset to First Record.
Paul
That did it...thanks, Jason!
Paul
I went through the other thread about the repeating table and double-checked my code, it looks like it is fine. I am still getting the multiple categories and manufacturers even though I added "GROUP BY" in the SQL as you showed me. I have attached the file because I changed the connection back to localhost.
They are both working off different recordsets, but it is funny...sometimes when I open the default.php page, there is no recordset listed in the Bindings tab.
line 36:
$query_rsProducts = "SELECT * FROM products";
there is no GROUP BY for the products recordset.
Paul
That did it, Jason...
Paul
Hey Jason,
In the results pages you helped me with yesterday, for some reason when I opened and closed files, the recordsets were missing. I put them back in and all seemed fine. But now today, the categories_results page is showing this:
Notice: Undefined index: prodName in C:\xampp\htdocs\Century\categories_results.php on line 18
Here is line 18: $WADbSearch1->keywordComparison($KeyArr1,"".$_GET['prodName'] ."","AND","Includes",",%20","%20","%22","%22",0);
I've attached the page for your reference...
change line 18:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET['prodName'])?$_GET['prodName']:"")) ."","AND","Includes",",%20","%20","%22","%22",0);
