Transfer of State/Province and Country in the CheckOut process
Thread begun 6/10/2013 7:58 am by Kamen Nikolov | Last modified 6/10/2013 6:22 pm by Kamen Nikolov | 1983 views | 4 replies |
Kamen Nikolov
I was wondering why is the information regarding State/Province and Country in the profile not transferring through the CheckOut process and I have to fill this info out even-though it is in the profile?
Thank you.
i dont follow, can you give more details.
Kamen Nikolov
In order to purchase on line you will create a profile -> you log in and you have all info in your profile (name, address, city, state, country, telephone and so on). All fields are text fields but the Country. Wen you go to the CheckOut both State and Country in the Billing Information and Shipping Information are drop dynamic list menus and they don't keep/transfer the correct information from the profile.
Am I making myself clear?
ok, that is more clear.
for the select lists, click the dynamic option in the property inspector, for the Select option equal to, click the lightning bolt icon and select the corresponding column from your table.
NOTE: Make sure the registration form and the checkout form use the same values.
for example, if the registration form uses the full country name and the checkout form uses the country abbreviation, this wont work.
Kamen Nikolov
Thank you. I will check it out.
Update: Hi I have check and the Registration form was using full name for both and the CheckOut form was using abbreviation. Problem solved.
Thank you.
P.S. Maybe this is a glitch because they should be the same since they were generated by the same program.
