Disable jQuery when using inline editor
Thread begun 5/30/2013 2:53 pm by elevy388997 | Last modified 5/31/2013 12:27 pm by Jason Byrnes | 1674 views | 3 replies |
elevy388997Beta Tester
Hello,
When activating the new inline powerCMS editor it causes a slight hiccup in the jQuery I have on the page. Right now there is an according panel displaying a bunch of information and when you click on a heading, you see some new text. The inline editor defaults to the top most code of text and only lets me edit that. How can I disable jQuery when using the editor so it shows up as a normal heading then text, then when logged out, reverts back to the jquery accordion version...? http://www.djembroiderycenter.com/services.php
it's not possible to disable the jquery, it would be better to disable inline editing and edit that section using the admin screen only.
to disable inline editing on a particular page, edit the developer notes for that content area and add a fifth parameter as TRUE, for example:
<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'page name''content name',true); ?>
Awesome, thanks for the workaround.
When I edit the section using the admin screen, I see the same exact thing that was presented to me with the inline editor. I get all the headings and the first paragraph of text. When I click on source code, I can see the other paragraphs that should be showing up. See attachments.
1 - Actual webpage showing additional section with paragraph
2 - Very same page refreshed after logged into admin ( I lose all sections but first )
3 - Admin WYSIWYG editor
4 - Source code in admin area - Yellow is what is showing - Purple is additional text that isn't there in admin mode.
I think you will ned to edit the content in source code then.
