Data Assist does not enter a field for 'tourDisplay' when creating UPDATE & EDIT pages
Thread begun 5/23/2013 2:43 am by fire MUNKY (Roy) | Last modified 5/23/2013 9:16 am by Jason Byrnes | 1469 views | 3 replies |
fire MUNKY (Roy)
Hi
I have been using Data Assist for years and always used 'bit' format for Display with a 1 or 0 to represent Yes or No.
Just creating a set of Admin pages for a client and the page concerned has tour dates which I want to either show or not show....
hence 1 for Display and 0 for Don't.
The problem is that Data Assist is not producing a field to update or insert. It produces a label but nothing else.
Previously I have changed the result to a Menu List, which has Yes = value 1 and No = value 0.
Just wondered what is going on, maybe I am using the wrong data type?
It has me puzzled.
I attach the mySQL data table with data, and screen shots of code view - browser view and the page it is affecting at hollywoodu2.com
Your help is appreciated
Roy Clay
What version of Data Assist are you using?
The older Data Assist 2.x? Or are you using Data Bridge?
What is your OS?
once i know what version you are using i can try to reproduce the problem and find the cause.
fire MUNKY (Roy)
Versions and OS
Hi Jason,
I am using Data Bridge 1.1.3
I also use eCart 5.0.7 / Design Extender 1.1.2 and Free Tools 1.0.2
I installed them in the order of eCart - Design Extender - Free Tools and Data Bridge last
I am using Dreamweaver CS6 as part of Adobe Creative Suite CS6 Subscription
Windows 8 64 Bit OS
I hope that helps
Roy
Thanks, i have recreated the problem and logged it as a bug. it will be corrected in the next update to data bridge.
in the mean time, the work around is to edit the field settings on the manage pages tab and check the Display as option for the tourDisplay column to Checkbox
