Ability to change validations on insert, update and search
Thread begun 5/08/2013 9:25 am by mrs | Last modified 5/08/2013 9:40 am by mrs | 1138 views | 2 replies |
mrs
Would it be possible to create data assist where we can have different validations for the insert, the update and the search pages. From memory and before data bridge, the step through process of data assist used to take settings from the insert page and then apply it to the update and the search pages.
It would be useful to have something where the validations could be set on the insert page as this is often where most validation is required, and then be able to remove any validations not required on the update, and certainly on the search page... after all, the search page really shouldn't have validation on it because the user might only want to search in a field that doesn't have any validation applied. Forcing a user to enter content in the search because the form won't submit will more often than not return no results even though there might be some in the DB.
You would need to edit the validations on the pages after they are created for this.
mrs
Yeah, I always struggle with that... never mind. I was hoping it might be something that I could do within data assist and then save it as a preset. I am using a lot of presets at the mo' and it is really speeding up my dev time, so it would've been a useful addition. If it's not possible then fair enough.
