Content pages npt displaying under Content sidebar
Thread begun 4/22/2013 4:04 pm by jleahy350963 | Last modified 4/26/2013 4:17 pm by jleahy350963 | 2621 views | 6 replies |
jleahy350963
Using PowerCMS on a site. Added content successfully locally and live.
I had 7 pages in a category called "Concepts". When I added the 8th page, only 4 now show in the left column of the admin screen.
I reproduced the error locally and on the live site. I also deleted all 8 pages and started again. When I added content for the 8th page, the list again now shows only 4 pages.
If the CMS is grouping pages by 4, there should be a 'next page' link but there is not. Since this happens both locally and live and the error has been duplicated, is there a fix for this? I have 200+ pages to add using PowerCMS, am at page 55, and stuck.
Also, I cannot afford to buy the new "design extender" package as it is just too expensive.
Suggestions?
I am using Ver. 1.01
Apache/PHP/MySQL
Not a memory issue, since I have added more pages to another section after this glitch came up.
Thanks for the support, and best regards.
jleahy350963
FTP access
Info moved to private section
Need some more information, see private message
jleahy350963
database access
In private message.
This was a problem with the Data Size for the pcms2_contents.ContentValue column. that column has a Text Data type which has a max size of 65,535 bytes. The content you adding to the E-D content are was just above that limit causing closing togs to be lost.
I changed the data type to Medium Text which has a max size of 16,777,215 bytes to prevent the problem from happening again.
jleahy350963
Thank you
I would not have looked there.
Thank you for your time, and I will note this for the future.
Great support.
