Products Update
Thread begun 4/13/2013 12:20 pm by rogersds267040 | Last modified 4/16/2013 9:43 am by rogersds267040 | 2956 views | 7 replies |
rogersds267040
Products Update
I'm not able to:
1: The browse button does not work to be able to view images. - See attachment
2: How do I change the background in ckeditor. - See attachment
1) I'll need to look into the files directly to troubleshott the problem, see the private section.
2) The HTML Editor body uses the themes css/configurable.css file.the ps_pod1 class is used for the HTMNL editor body, di you edit that to have a background image?
rogersds267040
Products Update
See private message.
Need more information, see private message
rogersds267040
You have edited the product update page to remove the checkbox to set an item as a digital good, this is causing java script errors, the javascript errors are causing the item image button to fail.
I updated the admin/scripts/product_update.js file to correct the JS errors.
rogersds267040
Thank you sir.
