Online products configurator
Thread begun 4/10/2013 1:38 am by Mike | Last modified 4/10/2013 7:38 am by Jason Byrnes | 977 views | 2 replies |
Mike
I'd like to realize a configurator similar to this:
http://www.youtailor.it/configurator/shirt
Is possible with your extensions?
If not, do you have something to suggest (jquery plugin, etc.)?
Thanks,
Michele
The configuration itself is not posible with the webassist extensions, you would need to use something like jquery to make that possible.
in eCart, you would need a column in the cart for each option. In the add to cart button, set each option column to be updatable from a select list.
this wil add the select lists to the page that you can use a base for the jquery functions to add the configuration display.
