Map not showing correct location via recordset or static postcode
Thread began 8/12/2009 3:04 pm by greg80809 | Last modified 8/14/2009 3:07 pm by jon_upton | 2304 views | 2 replies |
greg80809
I have an issue whereby my site won't display the correct location on the map if using just a UK postcode via a recordset. As this won't display I have also tried adding the street address as a static entry and also via a recordset - both failed to display correctly.
I have seen similar issues on other threads but no solution has been offered.
Is it the geo-cache causing the problem as it only seems to reference 3 addresses, surely this should contain all addresses?
Any pointer helpful as I have had to pull the plug on the maps for the time being whilst i can get it working.
thanks in advance
The Geocoder used by the maps API can sometimes have problems with UK addresses. In these cases, it is best to use latitude and Longitude coordinates.
One way to find the coordinates is to search for your address at maps.google.com, when you find the address enter the following scriptlet in the address bar:
javascript:void(prompt('',gApplication.getMap().getCenter()));
This show a javascript alert box with the latitude and longitude coordinates to use.
In promaps for google, change the Type attribute from Address to Coordinates to enter the latitude and longitude.
jon_upton
Discussed many times before
Greg
There are several threads discussing this it pays to look back through previous posts
see this post here showthread.php?t=1962
regards
Jon
