updating index page
Thread begun 4/02/2013 4:18 pm by Roz431315 | Last modified 7/08/2013 7:55 am by Jason Byrnes | 6647 views | 28 replies |
Roz431315
updating index page
Ray modified my site by creating a new gallery associated with a category called "new arrivals". in \gallaries\new_arrivals.
That works fine, I would like to make it so it is not editable in the store manger. The admin might delete it by accident. The code in index.dwt.php is below.
What changes do I have to make to the code below so the page looks like the attachment and is not editable form the store manage?
<!--<div class="banner ps_pod4">-->
<div class="NewArrivalText">New Arrivals</div>
<div class="info">
<?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Middle Pod' , 'Content'); ?>
</div>
</div>
I change the PHP code to this:
<?php include ('../../../../galleries/new_arrivals/index.php'); ?>
and I got I get this error message on the live index page:
Notice: Undefined index: gallery in C:\xampp\htdocs\relicvintage\galleries\new_arrivals\index.php on line 42
second line below is line 42:
//gallery id, theme
if(empty($pg_id)) $pg_id = $_GET['gallery'];
if(empty($pg_theme)) $pg_theme = 'dark';
if(isset($_GET['theme'])) $pg_theme = strtolower($_GET['theme']);
Thanks in advance for your help and patience, Roz
change:
<?php echo WA_getCMSContent($database_PowerStoreConnection$PowerStoreConnection'Middle Pod' 'Content'); ?>
<?php echo WA_getCMSContent($database_PowerStoreConnection$PowerStoreConnection'Middle Pod' 'Content'true); ?>
Roz431315
Update index.dwt.php
Hi Jason, thank you for that change.
I can see that the that the admin can not click in the upper left corner of that pod to edit from the home page.
When I log into the store manager as a admin (not super admin) I can't delete the pod but I can still edit the pod/ gallery. is there a way to prevent anyone from updating this part of the home page?
Maybe there is a better approach. I basically copied & pasted the "banner ps_pod4". The first displays the content "store message". The second pulls in the "new_arrivals gallery. Working with Ray, this gallery displays products and then brings you to the product detail page. I would prefer that this could only be edited through the code, is that possible? Is there another way to pull the gallery into the home page?
This is what the code looks like now:
<div class="info"><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection,"Home Page", "Site Message"); ?>
</div>
</div>
<div class="info">
<?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Middle Pod' , 'Content', true); ?>
</div>
</div>
No, there is not a way to prevent that content form being edited from the contents list.
Roz431315
Menu & Check out
I have a ghost sub-menu under the label "Policy" http://www.relicvintage.com/index.php there is a htaccess file pointing to a construction page.
the attachment shows the store manage showing that there should be 3 editable regions, however there is only one that I see..
I think a few days ago might of changed the "current location" drop down menu in store manager to another location.
Is there a way ti fix this either in store manager or a file to edit?
There is also an issue with the sub-menus for the products for Jewelry (Bracelets, necklaces, Rings)...when you hover over Jewelry and move cursor to one of the sub categories the menu disappears and does not let you select it.
Is there a way to increase the size of the order total and amount on the cart check-out page.
http://www.relicvintage.com/cart.php
The product search, continue shopping, clear cart and update cart...the mouse doesn't change, is that normal? as a fix I updated the hover on them with a border and background color.
For the Custom Menu, your screen shot shows a Content Section, but no Header or Menu Label
Click the Add Content Button to add a new content for the Custom Menu Section, name the new content area:
Menu Label
add another one, and name it:
Header
in the Menu Label Content, add the text you would like to show in the menu.
for the menu issue, add the following CSS to the webassist/themes/RelicVintage1/css/configurable.css file:
#cssmw ul.level-2 > li {
margin-left: -14px;
to change the order total size, edit the webassist/plugins/shopping_cart/cart.css file
add a font size tothe .cartSummaryWrapper .details table td.total and .cartSummaryWrapper .details table th.total selectors
Roz431315
Thanks for order total font size and the sub categories menu.
Still have issues with the menu labeled"Policy", first is there a way to keep the menu from displaying 2 lines if I was to label it "Customer Service" when I do that is go to 2 lines and looks ugly.
Second when I try to add a (Header and Menu Label) I get already exists...see attached
Third, the you hover over the (Policy ) menu label there is a ghost sub menu that has a brown background and takes you this this page:http://www.relicvintage.com/page.php?Custom%20Pages=
Thanks Roz
for the menu, you would need to edit the CSS to make the menu width wider to allow for the 2 words to be on one line.
for the missing item, i'll need to access the site files to troubleshoot.
Roz431315
I am posting the info you requested
I am not able to access the server using the information you provided
