added new "add to cart" buttons and put in test mode, checkout now failing
Thread begun 3/22/2013 9:50 am by Brendan | Last modified 3/22/2013 12:12 pm by Jason Byrnes | 3821 views | 7 replies |
Brendan
I am working with a checkout page that was working great as recently as a month ago. I added 2 new add to cart items, which are adding to the cart correctly, however, I put Authorize.net into test mode, and changed the code on the confirm page to "x_test_request - TRUE".
When I go through checkout, complete all of the required fields, then click checkout, the form clears, and the transaction is not logged to the orders or order details tables in my DB.
My checkout page is checkout.php
could be a php error occurring, add the following code at line 1 to turn on error reporting:
error_reporting
(E_ALL);
did you add server validation to the confirm page? it could be that the form is failing validation. if you are using server validation, you should include validation error messages on the checkout page.
Brendan
Here is what is showing after I added the error reporting code to the checkout page
<br /><b>Notice</b>: Undefined index: eCartCheckoutForm_cc_number in <b>/home/rssfund/public_html/checkout.php</b> on line <b>94</b><br />
I do have validations, but also have a validation show if with *** to identify what didn't pass validation...no validation errors are showing up.
ok, so what is the code at line 94?
Brendan
sorry, I thought I had pasted that in...
<td><input type="text" name="cc_number" id="cc_number" value="<?php echo $_SESSION['eCartCheckoutForm_cc_number']; ?>" />
should be:
value="<?php echo(isset($_SESSION['eCartCheckoutForm_cc_number'])?$_SESSION['eCartCheckoutForm_cc_number']:""); ?>"
but i still think the problem is validation.
the validation will be on the confirm page, on the confirm page, look for the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"index");
and change it to:
    die($WAFV_Errors);
if validation is failing, it will write a comma separated list of of numbers to the page corresponding to the validations that failed.
Brendan
there were a couple of validations failing, so I'll have to fix the "show if" validation statements in the checkout form.
Thanks for all the help!!!!
you're welcome, i had a feeling it was validations.
