Javascript Error
Thread begun 3/20/2013 6:42 pm by babroo138555 | Last modified 3/22/2013 8:59 am by Jason Byrnes | 3126 views | 6 replies |
babroo138555
Javascript Error
Hello, I keep getting this message when using the script.
you reported this same error in another thread:
showthread.php?t=30276
In that thread I asked the following questions:
What steps are you taking to get this error?
if you create a new blank PHP page, do you get the same error?
If not, send a copy of the page that you are getting the error on
babroo138555
Video
I erase that post and open this thread.
Here's a video of how I am using DataAssist.
watch?v=g8EH3iLLrBs
So you are using Data Assist 2. Do you have the latest version 2.1.0 installed?
What other extensions, including the version numbers are installed?
The code at line specified in the error seams to have to do with the filtering for the results page.
what if you don't set the filtering section on step 4 of the wizard? After the results page is created, you can edit the recordset on the results page to add the filter.
babroo138555
I'll try that later tonight. I'm at work right now. I'm just using DataAssist for now. I'll install my other extensions later.
babroo138555
the tedtmon
It work with the twist you said.
However I am not confortable with having to go into the code to fix it and have it work the way I want.
Must be a minor bug.
You don't have to go into the code, you just need to edit the recordset behavior after the page is created.
I think the issue is being caused by the spanish language version of DW that you are using.
In the code just near the error message, it is checking for whether an entered value was selected or not, your DW Version must be passing a different string for the selected value which is causing the error.
the work around will be to edit the recordset after the results page is created.
