java errors
Thread begun 2/28/2013 11:18 am by randyw2394710 | Last modified 3/01/2013 7:31 am by Jason Byrnes | 4530 views | 5 replies |
randyw2394710
java errors
i get these java errors at the last step while building the forms
javaScript error while loading wa_entries.htm
unable to open script file "c:\program files\adobe dreamweaver cs4\configuration\sharedwebassist\form\validation\wafv_ssvariables_sb.js"(error 3)
then i click ok and another appeaars
while executing onclick in wa_appbuilder.htm, the following javascript errors occured
at line 549 of file "c:\program files\adobe dreamweaver cs4\configuration\shared\common\scripts\dwscriptsServer.js":
dslist has no proerties
what extensions, including the version numbers are installed?
randyw2394710
i have these installed. i already reset the work space layout
theme it 1.0.1
validation tooltips for spry 1.0.1
surveyor 1.0.5
design extender 1.1.1
security assist 1.1.9
css form builder 2.0.0
css menu writer 2.0.3
dynamic dropdowns 2.7.4
eric meyeres 3.0.2
site import 3.0.3
cookies toolkit 3.1.3
ecart 4.5.2
data assist 2.1.0
you have a few extensions installed that are included as a part of design extender:
eric meyeres 3.0.2
site import 3.0.3
uninstall those extension, and uninstall design extender, then re install design extender.
randyw2394710
im still having same problems after uninstalling all of those extensions and re installing design extender
In your list, you have css form builder 2.0.2, the most recent version of form builder 2 is 2.0.1
since your installing this along side design extender, you will uninstall both form builder, and design extender before installing the updated form builder version,
I would suggest looking into upgrading to Data Bridge, IT would give you newer versions of Data Assist, and Security Assist and it would prevent these sorts of conflicts
if you contact the Sales department, you can get an upgrade discount as low as $149.99
babroo138555
I too get the same error
I'll move this to a new post.
This is a completely different error than what was reported by the OP.
What steps are you taking to get this error?
if you create a new blank PHP page, do you get the same error?
If not, send a copy of the page that you are getting the error on
