Problem with DW CS6?
Thread begun 3/18/2013 3:12 pm by LWag48648773 | Last modified 6/03/2013 10:08 am by Jason Byrnes | 6487 views | 19 replies |
LWag48648773
This is the 1st time I'm using Data Assist since upgrading to CS6. Does anyone know of issues? I got thru the whole wizard and DW either crashes at the end or freezes up. I've tried several times. Rebooted, uninstalled the extension and reinstalled. Same thing every time. I hope there is some, easy fix.
Thank you,
Laura
LWag48648773
working on my laptop
I just got it to work on my laptop. Also running DW CS6 and Windows 7. Could I have some sort of conflict with something on my desktop?
oops - spoke too soon. Worked once on laptop. Tried again and DW freezes up every time.
Arre you using the stand alone version of Data Assist 2? That version is not compatible with DW CS6.
It has been replaced By Data Bridge which contain an updated version of Data Assist along with other extensions.
to use Data Assist with DW CS6, you will need to upgrade to Data Bridge. depending on your purchase history, you may qualify for an upgrade discount as low as $149, contact the sales department for more details.
LWag48648773
Thanks Jason. I was afraid it was something like that. I'd complain about the fact that I'm forced to upgrade but I looked at DataBridge and it looks like a really nice upgrade, combining and making better what I already have. I obviously don't use these extensions often but it's really nice to know I have something I can go to when I need it and I've been coming back to WebAssist for years. I always know I'll get answered on the forum too.
Thanks again.
Vlad
Install Suite, but ...
it crash dreamweaver - Mac 10.8, CS6
when You try make any data page and not only :-(
I understand DW sometime crashed, but when using this extension ... at 100% case
What extensions including the version numnbers are installed?
the extensions that are compatible with DW CS6 are:
eCart 5
Free Tools
Design Extender
Data Bridge
and should be installed in that order.
you say it crashes while running the Data Assist Create Pages wizard?
at what part of the process?
are you using on of the application presets?
are you using your own table? or one of the preset tables?
If your own table, send a copy of the SQL structure so i can try to replicate the problem.
It may that you are using a reserved word for a column name, or it may be one of the datatypes used.
if you can provide more details i can investigate the cause.
Vlad
ok, i try to reinstall in this order (it very strange for me - for example I install free tools first), but i do it, and test again
THanks for quick response!
Vlad
it's really help :-)
thanks!
glad to hear it is working.
Vlad
work, i would be happy when it start work - as i wait :-)
