Use a dropdown to dynamic sort records
Thread begun 3/15/2013 2:17 pm by pedstone | Last modified 3/17/2013 2:49 am by Dave Buchholz | 2697 views | 3 replies |
pedstone
What i want to do is to have a dropdown that let's users sort a recordset.
For example: newest first, oldest first, Name A-Z, Name Z-A
So my idea was to set a session variable with the values from the dropdown list on change, having the dropdown in a form and submit that form on change.
Example of the dropdown:
Label: Newest first Value: Date DESC (where Date is the column name to sort)
(This works and sets the correct values in the session variable)
Then add a variable called "Sorter" in the recordset query that reads the session variable and use that variable like this: ORDER BY Sorter
expecting the recordset would be sorted by the value in the session variable.
That's where I got stuck now as the sorting doesnt works.
Did I choose a complete wrong approach or did i miss to pay attention to some detail?
DarylBeta Tester
Try having a read of this http://www.blazingimages.com/sortable-rows-with-data-assist-version-2 it is a different approach but has been used by a number of other people here to accomplish something similar.
Credit - The solution was created by Neo on this forum and not by me..
pedstone
Thanks for that hint Daryl
in the meantime I found another interesting solution for this here:
php-sorting-a-list-using-a-drop-down-menu
With little adaptions I got it to work and hope this solution might help some other members too.
Hopefully Webassist might come up with a feature like this, as its specially useful on e-commerce sites
Dave BuchholzBeta Tester
I have used a cookie created by a dropdown list as demonstrated here http://www.tshirt-town.com/sale/clearance-offers.php
The process is that I create a cookie onchange from the select list and submit back to the page via javascript then check the value submitted like so
switch($_COOKIE["sortBy"]) {
    case "newest":
    $orderClause = "tbl_products.tstampinsert DESC, tbl_products.title";
    break;
    case "a-z":
    $orderClause = "tbl_products.title, tbl_products.sortorder";
    break;
    case "z-a":
    $orderClause = "tbl_products.title DESC, tbl_products.sortorder";
    break;
    default:
    // default behaviour
    $orderClause = "tbl_products.sortorder, tbl_products.title";
Then you need to add the resulting var into the recordset like so:
AND tbl_subcategories.slug = %s ORDER BY " . $orderClause . "", GetSQLValueString...
