UE not sending email / two form elements newly added
Thread begun 3/11/2013 1:22 am by rikaG_510 | Last modified 3/18/2013 7:52 am by Jason Byrnes | 2931 views | 5 replies |
rikaG_510
Hello,
This post is non-related to what I posted regarding contact form and UE yesterday.
I've added two more form elements ("ad_detail" and "del_detail" both are text field) to checkout.php for my shopping site. (All the form elements given by eCart are used up.)
Both are stored in "Orders" table in Database.
I managed to make it work, it sends data to remote database perfectly (by clicking submit button on confirm.php). But Universal Email isn't sending any email, even to a directly typed in email address. I didn't think I did anything different from last time, and spent some good hours, but cannot figure out what is wrong.
The only difference are two form elements newly added, so I'm wondering, if there's any coding I'm supposed to add to some files relating to Universal Email? It would be great if you could take a look at files.
Confirm.php and checkout_success.php has error display code, but no error appearing when tested online.
FYI, I use 123-reg hosting, and I know this isn't a problem as other forms are working fine without SMTP setting.
I attached files that you might need to take a look.
Thank you always, for your help
Rika
p.s. by the way I am using DataBridge for some while, not Universal Email, to be precise.
on the confirm page, there are 2 problems i can see:
1) The order of operations is:
Store Order Summary
Store Order Details
Send Email
but in the store order details behavior, you have it set to redirect to the success page, this redirect will happen before the the email can be sent
edit the store order details behavior, and make sure it does not redirect.
2) in the universal EMail behavior, you have the To address set to use the eCartCheckoutForm_postcode binding, this is not a valid email address. you should use the eCartCheckoutForm_email binding instead.
rikaG_510
Hi Jason,
1) solved the problem.
("2)" doesn't sound right, but I applied postcode to store email address, so it's not an issue.)
Thank you!
Ok, so are the email working now that you have made those changes?
rikaG_510
Yes!
For the confirmation page, I just fixed "1) - edit the store order details behavior not to redirect."
("2)" - left it as it was as I'd set the "postcode" to stores email address when I initially created the site.)
Also, I deleted "the mail_php.php" and "mailformatting_php.php" files, then went back to the UE server behavior to regenerate those files, which was done for my contact.php file since you suggested to do this in another thread I posted.
Contact and confirm pages are in the same site, so not really sure if I just needed the former or both to fixed the problem for confirm page.
But it is sending emails with no problem.
Again, thank you for your help!
Ok, Glad to hear it is working.
