Link from Google map to maps.google.com
Thread begun 3/09/2013 9:51 am by bryan107833 | Last modified 3/11/2013 7:16 am by Jason Byrnes | 1136 views | 1 replies |
bryan107833
It seems that the map I have created should surely link to the google map site so that a client can get directions etc. but there seems to be no place to put this?.. Also, the info box is way to big.. I see a thread that gives a solution to simply get it to stop showing at all -
if (isDefault) {
infowindow.open(map4,marker);
map4.setCenter(point);
setTimeout("google.maps.event.trigger(wagmp_map_4_obj.markers["+wagmp_map_4_obj.markers.length+"],'click')",1000);
But that doesn't really seem like the best solution.
Thoughts? The link is the most important issue currently.
Thank you.
No, Pro maps does not automatically generate links back to the map on the google site.
to add the ability for directions, you should make sure that your page is a dynamic PHP page. you can then add a form for street address, city state and zip code.
In the pro maps wizard, on the Driving directions page, enable driving directions, and bind each of the settings to the corresponding form element,
