Error starting website on localhost
Thread begun 3/09/2013 9:12 am by glozinski107205 | Last modified 3/11/2013 6:35 am by Jason Byrnes | 2259 views | 3 replies |
glozinski107205
PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 2 PHP Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 2 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 2 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 4 PHP Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 4 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 5 PHP Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 5 PHP Warning: strtotime() [function.strtotime]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 5 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 6 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 6 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 9 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 9 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\themes\Default\images\installed.png on line 33 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\plugins\catalog\scripts\resize_image.php on line 258 PHP Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/Los_Angeles' for '-8.0/no DST' instead in C:\inetpub\wwwroot\dp_store\webassist\plugins\catalog\scripts\resize_image.php on line 258
what file is causing this error...thank you in advance.
inetpub is to do with IIS which is .net framework isn't it?! Which is all part of windows server. You need to be running a Linux based server in windows such as WAMPSERVER (which is a popular one) or XAMPP (which is what I started to use on Windows 8. They both are very easy to install and setup. And contain the PHP/MySQL and Apache server all required to use WebAssist extensions since they are all PHP based. So I would deactivate IIS service if your not using it (since it could interfere with the ports needed to communicate with your WAMP setup.
Chris
glozinski107205
I am running on windows 7 pro...this just happened it was working fine not sure whata caused it iis is set up properly thank you
in the php.ini file, there is no timezone set for the date.timezone
Edit the php.ini file and enter a vlid timezone for the date.timezone setting. For a listing of timezones that can be used, see this page:
timezones.php
