Mysql from 2 tables
Thread begun 2/11/2013 4:54 am by chris250441 | Last modified 6/08/2013 12:20 am by superpac250441 | 11273 views | 37 replies |
chris250441
Mysql from 2 tables
I wonder if someone could assist. I am trying to bring the order of presentation from one table and present the information on the page using the order in another table where the common factor in both tables is the url.
I have tried the following (and could be miles off track) and am getting a syntax error
mysql_select_db($database_menuConn, $menuConn);
$query_rsCatsSubsProd = "SELECT Pageurl, Heading, ShortContentLeftPanel, ShortContent, Category, SubCategory FROM pages WHERE Category LIKE '%Adhesion%' AND SubCategory LIKE '%Pull Off Adhesion Tester%'
INNER JOIN productssubcategory ON productssubcategory.url = pages.Pageurl
ORDER BY productssubcategory.myorder ASC";
Any help would be greatly appreciated!!
i dont see an error in your syntax, do you get the syntax error when testing the recordset? or when viewing the page in the browser?
have tried running thee query directly in PHPMyAdmin or another MySQL GUI Tool? i find it helpful to use a GUI tool for getting the syntax correct before creating the recordset in DW.
see this page for details on the syntax for a join query:
sql_join_inner.asp
chris250441
Hi Jason, I get it when I test the page
have you tried testing the recordset in the recordset window?
have you tried the query in the MySQL GUI Tool?
if you can test the recordset in the recordset window, then the syntax error is coming from something else on the page.
chris250441
This is the error message:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'INNER JOIN productssubcategory ON productssubcategory.url = pages.Pageurl ORDER ' at line 2
ahh, right, i see. (Including the full error text is a definite plus)
the problem is that the inner join is after the where.
the inner join needs to come before the where clause, not after.
chris250441
Jason, I tested it by running the query in navicat and it seems to run just fine. That was before your last post.
The query I ran was :
SELECT Pageurl, Heading, ShortContentLeftPanel, ShortContent, Category, SubCategory FROM pages WHERE Category LIKE '%Adhesion%' AND SubCategory LIKE '%Pull Off Adhesion Tester%';
INNER JOIN productssubcategory ON productssubcategory.url = pages.Pageurl ORDER BY productssubcategory.myorder ASC";
Not sure what to do re your last post. Would you be kind enough to give me an example based on the above so that the inner join comes before the where clause as you suggested???
many thanks Jason
well, in your SQL, you have:
First you have the From section:
FROM pages
followed by the where clause:
followed by the inner join clause:
actually looking at the code for the where clause separately, there is a semi colon at the end that should not be there
instead of having the where clause code before the inner join, it should come after the Inner join
chris250441
Hi Jason,
I am still getting a problem. if I test the following query in navicat :
SELECT * FROM pages
INNER JOIN productsubcategory ON productsubcategory.url = pages.Pageurl
ORDER BY productsubcategory.myorder ASC"
I get the following error message:
[SQL] SELECT * FROM pages
[Err] 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '"' at line 4
In addition, please see attached the DW Test.
If I run the page in a browser with the following query:
$query_rsCatsSubsProd = "SELECT * FROM pages INNER JOIN productsubcategory ON productsubcategory.url = pages.Pageurl WHERE Category LIKE '%Adhesion%' AND SubCategory LIKE '%Pull Off Adhesion Tester%' ORDER BY productsubcategory.myorder ASC";
I get this message in the browser:
Illegal mix of collations (latin1_general_ci,IMPLICIT) and (latin1_swedish_ci,IMPLICIT) for operation '='
So I am now lost at sea!!
Can you see what I am doing wrong?
Your assistance is MUCH appreciated
your query:
SELECT * FROM pages
shouldnt have the quotes at the end.
the error:
is saying that the collation for the productsubcategory.url column and the pages.Pageurl column do not match.
