Data Bridge - Form
I want to change the size of the forms which are created on the product insert and product update page. I am not able to find the css rules to change it. Please can you tell me how to adjust the sizes.
the form width should only be constrained by the container it is is.
Using Fire Fox with FireBug you are able to select any areas of your page to see the CSS That is effecting that erea, you should be able to use Fire Bug to find the css to edit to increase the form width.
roadmap_10.php
Thanks I will try that. Also The form on the product insert page stays on the left side inside the container but I want to move it so it's in the centre. Can that be done also?
Many thanks
i'd need a link to see the problem to tell how to move the form to the center.
I'm testing the site on my local server, but I have attached a file. I want to change the outline of the form so its width is a bit smaller and also the html editor, I want to increase the width of that if possible. So I can then centre the whole form.
Cheers
You should be able to use Fire bug to find the CSS to edit for your changes, i wont be able to offer assistance without being able to see the page in a browser, i cannot troubleshoot CSS form a screen shot.
