DFP 2 problems
Thread begun 2/05/2013 12:42 pm by tom.kurshinsky298027 | Last modified 2/06/2013 9:05 am by Jason Byrnes | 2183 views | 5 replies |
DFP 2 problems
I use DA 2.1.0 and DFP 2.0.4. I have a simple page that, along with data, uploads a picture to the website. Standard stuff. However, using DFP 2 I cannot get it to work no matter what. If I use older code from DFP 1, it works just fine.
Now I have the issue again when working on an update page with a file field to be able to change the picture. The update page comes up, I select a new picure file, it seems as if it's uploading the picture then the page just goes blank and there has been no upload or changes to any other field. I have followed the PDF about how to do this to the letter I think. I've attached the page as a text file.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
OK, this is what I get.
Fatal error: Call to undefined function WA_DFP_UploadFiles() in /cars/techaspt/tech_Update.php on line 77
Line 77 is:
WA_DFP_UploadFiles("WA_UploadResult1", "picfile2", "0", "", "false", $WA_UploadResult1_Params);
that function should be defined in the WA_DigitalFilePro/HelperPHP.php file.
it may be that your copy has become corrupted. Here is a fresh copy of that file for you to upload to your server.
That was it. Thanks much.
you're welcome.
