str_replace
Thread begun 1/31/2013 2:20 am by JamieEff | Last modified 2/06/2013 8:27 am by JamieEff | 3284 views | 6 replies |
JamieEff
str_replace
is there a simpler way of expressing this please?
<a href="newsarticle.php?ID=<?php echo(str_replace(array(" ","!","?",",",".",";",":","'","/"),""$row_NewsRS['NewsTitle'])); ?>">
Do I need to list all the non standard characters (ie ! / , . ' @ etc) individually or is there a way of expressing it without having to list them out?
Also, with this is there a way of making upper case go to lower case?
Cheers
Jamie
so you want to only allows letters and numbers?
you could use a preg_replace() for that which takes a regular expression
<?php echo(preg_replace("/[^A-Za-z0-9]/"""$row_NewsRS['NewsTitle'])); ?>
See this thread also:
showthread.php?10349055-Remove-non-standard-characters-from-string
you can convert upper case to lower case using strtolower():
function.strtolower.php
JamieEff
Thanks Jason
Is there a way to combine that that with replacing a space between words with _
What I have tried (and hasnt worked) is:
<?php echo(str_replace(array(" "),"_", (preg_replace("/[^A-Za-z0-9_]/", "", $row_NewsRS['NewsTitle'])))); ?>
you include the underscore in the preg_replace() function:
dont include the underscore in the pregreplace function, you are replacing it with a blank there so it cannot be found in the result that the replace function is using.
JamieEff
but what i am trying to do is take something like this:
the cat sat on the mat!!!!
and make it into
the_cat_sat_on_the_mat
neither way is leaving the underscores in the sentence....
reverse the order so that your replacing the spaces with underscores directly on the recordset result, then using the preg_replace to strip other characters:
<?php echo(preg_replace("/[^A-Za-z0-9_]/"""str_replace(array(" "),"_", ($row_NewsRS['NewsTitle'])))); ?>
JamieEff
thanks Jason
