Insert form w/DataAssist
Thread began 1/23/2013 9:15 am by neil444064 | Last modified 1/23/2013 9:28 am by Jason Byrnes | 452 views | 1 replies |
neil444064
I am creating a blog with 2 tables One for the categories and one for the contents of the blog. The categories table has 2 col like this: id name.
The ContentsTable has columns like this: id catid title fulltext author
the catid in contentsTable is related to id in CategoriesTable.
My issue is i want to create an Insert Form to add new contents but I want to be able to have a dropdown list with the names of my categories instead of int's eg if i wanted to add an item to my category C whose id in the CategoriesTable is 3 and whose catid in the ContentsTable is 3, i would like my insert form to have a dropdown that allows the user to choose Category C instead of the int it is represented by. I hope this is clear. How would I do this with data assist? I am able to get all the pages but not that dropdown with category name instead of int.
create a recordset to return the category IDs and the Category names.
add a select list to the page, set it to be dynamic.
for value, use the Category ID column, for the label use the category name column
