Security assist login not working
Thread begun 1/22/2013 8:46 am by info298111 | Last modified 1/28/2013 8:47 am by Jason Byrnes | 7511 views | 12 replies |
info298111
I have been struggling with this for days now.
I have made a login page with standard settings from Databridge/Security assist 113.
login.php
It just keeps throwing errors at me:
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/content/login.php on line 28
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/content/login.php on line 33
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/content/login.php on line 48
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/content/login.php on line 53
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/webassist/security_assist/helper_php.php on line 56
I am totally stuck, please help
do you mean to say that you have both Data Bridge and Security assist 1.1.3 installed?
you should only have Data Bridge installed, not the stand alone version of security assist.
see this thread for details on troubleshooting the headers already sent error:
showthread.php?t=19285
if you need further assistance, I'll need a copy of the page in order to inspect the code.
info298111
Security assist
No, I mean security assist as packed in Databridge 113
info298111
Security assist
I did do all the checks, but no joy
Still errors:
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/content/login.php on line 38
Which is:
setcookie("RememberMePWD","".((isset($_POST["Log_In_group_userpass"]))?$_POST["Log_In_group_userpass"]:"")."", time()+(60*60*24*30),"/","",0);
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/content/login.php on line 43
Which is:
setcookie("RememberMeUN", "".((isset($_POST["Log_In_group_username"]))?$_POST["Log_In_group_username"]:"") ."", time()+(60*60*24*30), "/", "", 0);
Which is:
setcookie("AutoLoginUN", "", time()+(60*60*24*30), "/", "", 0);
Which is:
setcookie("AutoLoginPWD", "".((isset($_POST["Log_In_group_userpass"]))?$_POST["Log_In_group_userpass"]:"") ."", time()+(60*60*24*30), "/", "", 0);
Warning: Cannot modify header information - headers already sent by (output started at /usr/home/testworks.nl/htdocs/content/login.php:1) in /usr/home/testworks.nl/htdocs/webassist/security_assist/helper_php.php on line 62
Which is:
header("Location: ".$WA_Auth_Parameter["failRedirect"]);
So I still have the same problem
the error is reporting the error at line 1:
this usually means that the BOM Signature is enabled.
See the previously linked thread near the end.
if you need further assistance, compress the page to a zip archive and send the zip file so i can see the page code.
info298111
BOM signature is not enabled. Zip file was sent with original post, but here it is again.
info298111
Databridge mess
It appears the mess was caused by my SSD-drive messing things up. Installed DW CS5.5 on my Toshiba Qosmio, redid the thing and it is working now. Will replace SSD with WD-HD and start reinstalling all my progs and apps.
Thanks for your effords and my apologies for any inconvenience
I see no attachment to the original post.
looking at the login page, Dreamweaver is reporting to me that the BOM Signature _is_ enabled see the attached screen shot.
info298111
Very strange, as my DW told me it wasn't. I also noticed using ExtendStudio FlexiLayouts will manipulate url parameters causing errors in line 1 as well
info298111
CSS Frames
Originally Said By: info298111
After a lot of problems and testing I found that when placing databridge pages as well as ADDT pages in css frames, the mentioned errors occur. When using tables everything works fine. So css frames seem to cause these problems.
Just in case anyone wonders why I would place them in css frames: this is so I can insert a header and a menu to access the different pages for content management.
