Can't add Ecart object
Thread begun 8/10/2009 9:42 am by mfrohlich382893 | Last modified 8/10/2009 12:19 pm by Jimmy Wu | 2918 views | 3 replies |
mfrohlich382893
Hi, I can't add any ecart objects to my pages, they are all greyed out. I bought the Super Suite. My build on Dreamweaver is CS4 Version 10.0 Build 4117. I cannot find any tutorial files as well. I think it would be very helpful for me to go through a sample site. Is this available. I have looked at the help menu, but doesn't seem to address my problem. Thanks for your help.
Jimmy Wu
In order to use eCart in a Dreamweaver site you must make sure the following has been done:
1. Create a site in Dreamweaver including the local info and testing server.
2. For the testing server you will need to specify the server model or language you will be working in. You will also need to have the access portion specified.
3. Open up a page that matches the server model you choose for the testing server and save this page to the site.
4. With the page open you can add the eCart Object.
As far as tutorials, there are some files that may help in your Download Center. To get there, sign in to www.webassist.com and click on the "Your Account" link at the top right and then click on "My Downloads" on the right. On the download center you can select eCart and there should be some information on getting started.
There's also some information on the website under support.
mfrohlich382893
I already have a site. I just figured out what the problem was though. My site is hosted on an ASP enable server, and I have asp server side includes in the html, but the page itself was a html page. Once I saved it as an .asp page I was able to add the ecart object. Thanks for your time, very silly mistake on my end.
I would like to know if you have a sample cart that comes with the product download. I didn't see one, but it would be very beneficial for me to get started with a tutorial that actually uses a sample site you have created. Thanks
Jimmy Wu
There should be a complete store download in the download center under eCart GSG: Dynamic Completed Files for the server language you are using.
