WA_AuthTK_Auth_User - JavaScript Error
Thread begun 1/04/2013 4:37 am by FrankJay | Last modified 3/01/2013 1:07 pm by Jason Byrnes | 5223 views | 13 replies |
FrankJay
Do I have created a simple login system using security assist and my own database with the following user table. The fields are:
UserId, UserEmail, UserPassword, UserNames, UserLevel.
The simple login is only for the administrator of the backend.
When running security assist I deleted the standard suggested pages, registration, user update etc and only left with the login and logout pages. I have saved it as a preset and run it a few times. In my last attempt I've noticed under the manage Pages tab that my login and logout pages locations do not match what is specified at the bottom in the page location field. Screenshot attached.
I am wanting to generate these pages to a directory /ad_min/
After the two pages have been generated I am testing the standard login which is working by redirecting me to the login page with the message stating that I am logged in.
In the server behaviors panel I am double-clicking the security assist authenticated user to adjust the redirect page and to set the user level session.
I get some JavaScript errors with the user interface not been displayed at the end. I have searched the forums for these errors with no results.
This morning I even installed the latest version of data bridge 1.1.2 cleared my cache file and still getting the errors. I am attaching the generated pages and the screenshots of the errors.
Regards
Frank
What is your operating system?
What version of Dreamweaver Are you using?
What other extensions including the version numbers are installed?
FrankJay
Operating system and extensions
I'm using a Mac Pro with Mac OS X version 10.7.5 and Dreamweaver CS6 version 12.0 build 5861.
I have a host of DMX zone extensions. The list of webassist extension is:
eCart 5.0.6
design extender 1.1.1
data bridge 1.1.2
FrankJay
Solution
3 times of deleting the cache.dat file and rebooting my Mac seemed to solve this issue. Not sure if this problem was related to updating Dreamweaver CS6 earlier today.
ok, glad to hear it is working.
nuhu.abdulkadir418811
Same problem with WA_AuthTK_Auth_User javascript error
I am having the same problem using Security Assist to authenticate user.
See attached a screen shot of the error.
I have deleted the cache file several times, downloaded the latest version of DataBridge and re-installed, restarted my computer a couple of times and still dosen't work.
I'm using Dreamweaver CS6 on Windows 7 Ultimate. DataBridge version 1.1.3 installed.
How do I resolve this problem?
Is Data Bridge the only extension installed? or do you have others installed? if so what other extensions, and what are the version numbers?
Other extensions installed
Hi Jason,
I have the following extensions installed -
Design Extender 1.1.1
Ecart 5.0.7
I re-installed Data Bridge and Ecart already but no change.
what order did you install in?
you should install in this order:
eCart
Design Extender
Data Bridge
