IE 9 Display problem
Thread began 12/23/2012 12:53 pm by Rune Brynestad | Last modified 12/26/2012 11:30 am by Ray Borduin | 746 views | 1 replies |
Rune Brynestad
I have a DataAssist detail page. At the end of the page, after the closing form tag, I have inserted a DataAssist results page as a plugin. So far so good. It displays as it should in all browsers.
The problem starts when I'm starting to prepare the plugin page for a dynamic file download and have to add a form around the Download button and the hidden form field. This breaks the layout in IE9, but it looks good in all other browsers. I have tryed to remove the form tag that encircle the main container, but when I do, it looks even worse in IE9.
Do you have a workaround for IE 9?
Live URL here: filinfo_detail.php?Id=11
I'm also attaching the detail page and plugin page.
Regards
Rune
xide.zip
I'm opening a support incident to look into this with you directly. I don't quite understand what is going on, and I think we can help you through it more efficiently over the phone rather than using multiple back and forth posts in this forum.
