Insert field problem
Thread begun 11/30/2012 11:39 am by john70964 | Last modified 12/04/2012 12:34 pm by john70964 | 4444 views | 10 replies |
john70964
Hello
I am trying to get a dropdown field called Beam_Measure to insert into a table but so far have not been able to. Other similar fields work OK
As soon as I insert a value into the insert data options I get a red exclamation mark against the Insert Record SB.
If I use the form, the entry in that field never reaches the database table.
I deleted and re entered the field but still had the same problem.
I wondered if anyone can see where I am going wrong.
I am attaching the page and an image
Many thanks for any help.
Regards
John
In the file you have sent the Beam Measure DropDown list does not have any options to it?
Nor has it been bound in the insert behavior?
I would need to see the file where you have bound it to the insert behavior an added options to the list in order to tell why it may not be working.
john70964
Thanks for the quick answer Jason
I am attaching another file.
to help troubleshoot, change line 163 - 164:
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
  $MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
  echo($WA_Sql);
  $MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error()."|".$WA_Sql);
and post back the result
john70964
That seems to have worked and the field content has been inserted into the table.
Thank you so much for sorting out that problem Jason. Is there anything I should look out for in future so as not to cause that to happen?
Regards
John
that shouldn't have fixed the problem, only written the sql to the screen for troubleshooting that is what the line:
echo($WA_Sql);
should have don, if it is now woking, i suspect the changes weren't properly uploading to the server behavior, you should remove the echo statement from the page to prevent the SQL from being written to the page.
john70964
Thank you Jason,
I commented out the echo($WA_Sql); and tested the page and it updates the table OK.
I have one more problem with the page and that is with the selection of the currency field str_currency. In the DB table the field is a varchar length 50
At the moment the field is inserted with a 0 (zero)
I think I have the settings correct and cannot see why a zero should be entered in place of a string.
Can you see what may be incorrect please?
In the insert record behavior, the price column is set to use the numeric data Type.
Edit the insert record behavior and change the data type for the Price column to text.
john70964
Thanks Jason
The field that is showing the incorrect information is the str_currency field.
The price is inserted correctly as a number field.
The str_currency field in the db table is a varchar field but always 0 is entered when the form is used.
