Shipping Flat rate and UPS
Thread begun 11/26/2012 6:54 pm by nokkapok441461 | Last modified 12/03/2012 5:57 pm by nokkapok441461 | 4664 views | 9 replies |
nokkapok441461
I'm having trouble getting the shipping to work.
I would like to set the shipping option in the checkout page as select list for Flat Rate and UPS.
-I also would like to set it to free shipping for total amout that is less than 10$
-Flat rate would be depend on 1. Canada, US and 2. international.
I don't know how to set up to get the shipping to work for Canada Post so I just use UPS as the other option.
I added the select list in the check out page (right after shipping country in the same table.
<select name="ShippingOption" id="ShippingOption">
<option value="" selected="selected">Choose an option</option>
<option value="Flat Rate">Flat Rate</option>
<option value="UPS">UPS Standard</option>
</select>
I added hidden field in confirm page:
<input name="ShippingOption" type="hidden" id="ShippingOption" value="<?php echo((isset($_POST["ShippingOption"]))?$_POST["ShippingOption"]:"") ?>" />
and added 'set session value:
if((((isset($_POST["ShippingOption"]))?$_POST["ShippingOption"]:"") != "")) {
$_SESSION["ShippingOption"] = "".((isset($_POST["ShippingOption"]))?$_POST["ShippingOption"]:"") ."";
I also set triggers in shipping the Shopping cart object (I didn't add other stuff in the trigger such as free for purchase that is less than 7$ and international, Canada and US) just because I want to try if the shipping opions work.
Here's what I have.
Trigger for Flat Rate
If the value of the session varable 'ShippingObtion' is = a value of 'Flat Rate'
Calculation Flate rate = 10$
Trigger for UPS
If the value of the session varable 'ShippingObtion' is = a value of 'UPS'
Caculation Based on UPS shipping qoute value
But the shipping cost doesn't show up in the confirm page.
I'm not sure if I missed any step.
I'm not sure if the 'eCart UPS Shipping' supposed to be in server behavier for both check out and confirm page? I might've added it when I was trying things out and don't know if these might caused the problem.
Please help. Thank you
  Here's what I have.
Trigger for UPS
is this a typo? in both rules the session you are using is 'ShippingObtion', but it should be 'ShippingOption'
nokkapok441461
Sorry Jason, it's a typo it's actually 'ShippingOption'
I tried again and the flat rate seemed to work (just the basic trigger; without minimum price and based on countries)
But the ShippingOption=UPS still not working.
I'll need a copy of the pages please and screen shots showing how the rules are configured.
nokkapok441461
Here are some screen shots
nokkapok441461
Hi Jason,
Here is the file.
the Code for the USPS shipping server behavior needs to be moved further down the page so it is after the Set Session Value behaviors.
nokkapok441461
Hi Jason,
I moved the UPS in server behaviors down, still no luck. Not sure if it's the right location.
Please see in JPG screen shot.
if (($_SESSION['ShippingOption'] != "")) {
//WA eCart (Copyright 2007, WebAssist)
//WA eCart UPS Shipping - UPS
$Shipping_SuccessURL = "";
$Shipping_FailureURL = "";
$Shipping_Packaging = 0;
$Shipping_PackageArray = array();
$Shipping_PackageIndex = 0;
$Shipping_Counter = 0;
$Shipping_Parameters = array();
$Shipping_Parameters["UserID"] = "xxxxxx";
$Shipping_Parameters["Password"] = "xxxxxx";
$Shipping_Parameters["AccessKey"] = "xxxxxx";
$Shipping_Parameters["CarrierCode"] = "11";
$Shipping_Parameters["PickupType"] = "07";
$Shipping_Parameters["CustomerClass"] = "04";
$Shipping_Parameters["ShipperNumber"] = "xxxxxx";
$Shipping_Parameters["ShipperCity"] = "Ottawa";
$Shipping_Parameters["ShipperState"] = "ON";
$Shipping_Parameters["ShipperZip"] = "K2G 3W1";
$Shipping_Parameters["ShipperCountry"] = "Canada";
$Shipping_Parameters["ShiptoCity"] = "".$_SESSION['eCartCheckoutForm_shipping_city'] ."";
$Shipping_Parameters["ShiptoState"] = "".$_SESSION['eCartCheckoutForm_shipping_state_province'] ."";
$Shipping_Parameters["ShiptoZip"] = "".$_SESSION['eCartCheckoutForm_shipping_postcode'] ."";
$Shipping_Parameters["ShiptoCountry"] = "".$_SESSION['eCartCheckoutForm_shipping_country'] ."";
while (($Shipping_Packaging == 1 && !$nokkapok->EOF()) || ($Shipping_Packaging == 0 && $Shipping_Counter == 0)) {
if (WA_eCart_UPS_IsTrueValue("true")) {
$Shipping_PackageArray[] = array();
$Shipping_PackageIndex = sizeof($Shipping_PackageArray)-1;
$Shipping_PackageArray[$Shipping_PackageIndex]["eCart_Quantity"] = (($Shipping_Packaging == 1)?$nokkapok->DisplayInfo("Quantity"):1);
$Shipping_PackageArray[$Shipping_PackageIndex]["IsPackage"] = "true";
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "1";
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "LBS";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".$nokkapok->DisplayInfo("TotalWeight") ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "02";
$Shipping_PackageArray[$Shipping_PackageIndex]["SizeUnits"] = "IN";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageLength"] = "14";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWidth"] = "17";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageHeight"] = "1.5";
//Special Services
$Shipping_Counter++;
if ($Shipping_Packaging == 1) $nokkapok->MoveNext();
if ($Shipping_Packaging == 1) $nokkapok->MoveFirst();
$Shipping_Result = WA_eCart_UPS_GetRateQuote($nokkapok, $Shipping_Parameters, $Shipping_PackageArray);
if ($Shipping_Result && $Shipping_SuccessURL != "")
$nokkapok->redirStr = $Shipping_SuccessURL;
else if (!$Shipping_Result && $Shipping_FailureURL != "") {
Header("Location: " . $Shipping_FailureURL); exit;
else if (!isset($_SESSION["nokkapok_UPS_Success"])) {
WA_eCart_UPS_SetSessionDefaults($nokkapok);
nokkapok441461
Thank you, I've already put the link it in there.
