DataAssist and Windows 8
Thread begun 11/06/2012 11:19 am by Mark | Last modified 9/06/2013 7:51 am by Jason Byrnes | 6964 views | 13 replies |
MarkBeta Tester
Just wondered if anyone else is having problems using the Create DataAssist pages for insert, update, search etc pages?
I'm using Dreamweaver CS6, Windows 8.
Everytime I want to create these pages, I don't get to the end of trying to process these pages, because the program crashes?
Is it a case of waiting for the updated version of DataBRidge?
Mark
I dont think this is related to windows 8, it may be that you have your site definition set to synch files on save, this can cause the wizard to crash because it is creating many pages at a time and saving them causing Dreamweaver to go into an endless loop of synching the files while they get created.
MarkBeta Tester
Hi Jason,
Thanks for getting back.
No unfortunately, I switch off sync files for both local and server, and it still crashed out? I did test this facility under windows 7, and had no problem a week ago?
R, Mark
Rune Brynestad
I have exactly the same problem as described above with my new Windows 8 system. Sync files are switched off. Works perfect under Windows 7, but not under Windows 8.
Did you find a solution for it?
Regards
Rune
MarkBeta Tester
Hi, did you ever find the problem with data assist pages and windows 8 Jason, or did anyone else.
Even now, works perfect with windows 7 downwards, but keeps crashing when trying to create a results, insert and update pages?
If not, will just continue to use windows 7.
Cheers
Mark
are you using one of the application presets? or using New From Blank?
if you are using one of the presets, are you having Data Assist create the table, or using your own table? if using your own table, can you send a copy of the table structure.
in most cases, this has been an issue with the memory leak.
here are some things to try:
Delete the Dreamweaver Cache file from the users configuration folder:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
then restart the computer.
before running the wizard, close the Server Behaviors and Files panels.
anthony.tanner286315
Yes I am having the same issues. I got around it by making each page individually not ideal but it was a work around but I would to see a solution tpp
MarkBeta Tester
Hi Anthony, when you do them as individual pages, is there a link or something that you do to make them work all together (doing individual pages) or it is just case case of rattling individual pages off, for the set, one after another?
Also Anthony, do you have any DMXzone extensions or css layout extensions installed also, in the extension manager?
THanks
Mark
