Totally confused with securityassist
Thread began 10/31/2012 3:11 pm by CaptainPug | Last modified 11/01/2012 7:19 am by Jason Byrnes | 812 views | 1 replies |
CaptainPug
I bought supersuite just over a week ago and although I am impressed with the plugins, I am not that impressed with instructions for SecurityAssist.
Although the Dreamweaver security is nowhere near as in depth it is much simpler and I am totally overwhelmed by the rules etc of Security Assist at the moment.
For starters I have 'created security pages' which makes the necessary admin log in page, logout page etc. But then what? Do I have to do anything to the admin-login page that was created? I noted that the login page created has two 'securityassist authenticate users'. Am I meant to point both to the my 'if login succeeds go to' page?
I attempted to add it to one or the other and both, but all I get on every page I add 'secure page' to is a redirection to the 'access denied' page I have set up when I attempt to login. It doesn't matter what 'secure page' rule I choose (ie 'Administrator') etc on the pages I wish to secure, I still get redirected to the no-access page I have created.
The point is there is nothing I can find in support that says what you actually do and this is without setting up multi-level support, which I have to do next. It's fine saying securityassist does all these things but to newbees like myself it is utterly bewildering without being told how to do it or at least shown examples.
I have noted there is some archived material but all that does is confuse matters even more as this is the old security assist.
I'd really appreciate if someone has some detailed directions on creating security pages with the NEW securityassist, or at least has some example files showing how 'create security pages' works. This was meant to speed up my work flow but at the moment it certainly doesn't feel like it!
After Creating the Security Assist pages using the wizard, you should add access restriction to pages in your site that you wish to be protected.
You can do this on a page by page basis by applying the Secure Page server behavior (WebAssist -> Security Assist -> Secure Page) or by using the Access Pages manager (WebAssist -> Security Assist-> Manage Site Access -> Access Pages Manager).
There are a few default access rules that Security Assist creates, the access rule to use for protecting your pages is the "Logged Into <Your Users Table>" rule (where <Your Users Table> is the name of your users table).
In the wizard, there is the option to "Include the Remember Me option" and "Include the Automatic Login option" on the login page. If these options are enabled, the login page will have 2 authenticate user server behaviors added. one for when the login form is submitted, and the other for auto login. In this case, any changes that are made to one authenticate user behavior, should also be made to the other.
You mention that no matter which access rule you chose, you always directed to the access denied page, as mentioned above, make sure you use the "Logged Into <Your Users Table>" rule. If the problem persists using that rule, it may be that the server is not properly saving session variables. to test for this, use the session test script from the following thread:
showpost.php?p=23826&postcount=2
if the session test fails, you will need to contact the host to have them correct the problem, it is most likely a bad session.save_path setting in the php.ini file.
You also mention USer level Authentication. There is a tutorial for user level authentication on the Security Assist support page in the archived documentation section for user level authentication. It was written for v21, but the concept is the same in v2.
