NO REDIRECT - urgent help needed
Thread begun 10/24/2012 7:50 am by alib75702 | Last modified 10/25/2012 7:53 am by Jason Byrnes | 2914 views | 5 replies |
alib75702
I have put a straightforward add to cart button on a page - but the page will not redirect. Please can you take a look and see why this isn't working for me. The page can be found at:
help4health_products.php
could be a php error occurring causing the redirect to fail.
add the following code at line to turn on error reporting for troubleshooting purposes:
error_reporting
(E_ALL);
let me know when that code has been added and i'll take a look.
also, if you could send a copy of the /help4health_products.php page in a zip archive so i can examine the code, that would be helpful.
alib75702
Error messaging on
I have turned error messaging on but nothing showing ... also I am attaching a zip of the file. I have struggled with this on another bit of the site and got round it with a bit of handcoding but I would like to get it to work how it should. Thanks for your prompt help on this.
I see a couple places where there are spaces outside of the php tags, spaces outside of the PH tags will cause the redirects to break.
the first place is a space before the first php tag at line 1. the code at line one starts with a blank space:
" <?php"
that blank space should not be there:
"<?php"
the second instance is a blank line at line 12.
lines 9 - 13 are:
$eCart1
->GetContent();
<?php require_once('Connections/help4health.php'); ?>
the blank line at line 12 should be removed:
$eCart1
->GetContent();
alib75702
soaces
Hi - have removed the spaces and I am afraid it makes no difference! I would think if the spaces would make the redirect fail it would also make the addition to the basket fail too wouldn't it?
no, the spaces would not effect adding the item to the basket, it would only efect the redirect.
