DataAssist Pages (DB 108 and 109 on DW CS6) unexpectedly quits
Thread begun 10/10/2012 9:22 am by Alexneg66 | Last modified 12/26/2012 11:08 am by Patrice | 5635 views | 11 replies |
Alexneg66
I cannot use DataAssist Pages (DataBridge 1.0.9, but I tried the 108 too) because Dreamweaver CS6 unexpectedly quits before I finish to set up DA Pages.
I have also installed Design Extender 111, Free Tools 101 and Linecraft hideEmail 302.
I have already a database (MySQL) so I set up the control panels in this way:
Page Settings:
- Connection: my string
- Application Type = <New From blank> (Not create the db)
- Table and Key Column = my Table and my field
- Design Preset= Basic
Manage Pages:
- Configure Field Settings. In Database fields I set up some fields as Menu (and I choose an other Table and fields), others as text and "File manager", one Validate unique column value (ProdID). In Validations I set up same required fields and for some text fields I set up a number Max of Characters.
- Define Features. I am able to organize only a few pages (Search, Results) but before I am able to organize Insert or Update pages, Dreamweaver unexpectedly quits. So I'm not able to set up all the pages (Search, Results, Insert, Update) and nothing is writed on my HD. I try to change the order. It seems casual. I am able to organize two pages, then it quits.
It always happens when I just finished to set up for example the Results page and I click on OK buttons to return on Define Features (to add another pages): I'm not able to arrive on this last panel.
I tried many times, it's always the same things.
Oscar (Xavia Digital)
Re.
I have exactly the same problem, instead in Dw 5.5 and Cs6.
I have tried to reinstall all extensions, Dreamweaver, deleting .dat files (dreamweaver cache) etc, but still the same.
What is the solution?
thanks!
B Tonkin
Same here ...
Hey Jason,
This sounds like the same problem I was having.
showthread.php?t=28267
Can you keep me posted on if there is a solution or not?
- Bruce
if you respond to the incident i created for that thread, we can look into the issue with you directly to find out what is going on.
FrankJay
Me as well
I too am experiencing DW CS6 crashes.
Mac OS X 10.7.5
DataBridge 109
DesignExtender 111
I have uninstalled both extensions and reinstalled twice now. Deleted .dat file too.
The crash happens when selecting pages to administer.
Hope this helps. Look forward to speedy solution.
msbannister373603
Same issue
Looks like I'm experiencing the same problem. Can you provide guidance as to how this issue was resolved?
you p[posted this question to another thread as well:
showthread.php?t=29540
