Databridge Pages Crashes Dreaweaver 6
Thread begun 12/18/2012 3:26 pm by msbannister373603 | Last modified 5/23/2014 6:30 am by Jason Byrnes | 6807 views | 13 replies |
msbannister373603
I installed the new version of Databridge and it keeps crashing as I run the wizard to create insert pages etc... I've tried everything to fix it that I've read from the previous posts. This is very frustrating. It seems to crash with no reason at different stages of the wizard.
what access point are you using to start the Wizard?
Are you using an Application or design Preset? If so which one?
Do you have a Database connection defined and tested before starting the wizard?
Are you using your own database table, or one of the tables created by the wizard?
Does the crash happen while configuring the wizard or after finishing it during page creation?
The more details you can provide on the steps you are taking within the wizard before the crash occurs, the better the chance i can reproduce the problem and possibly determine the cause.
msbannister373603
Databridge Crash
I've tried it with both the presets and the unstyled settings and both crash
I do have a tested database connection before I run the wizard. I'm using wamp, and Navicat 10.
I am using my own database tables
The crash happens at various stages while running the wizard. Sometimes it will crash while structuring the insert page. Next I will try to create another page first such as the update page however it still crashes. The wizard never finishes running.
Do you have a PHP open in Dreamweaver that is saved to your site before you start the wizard?
msbannister373603
yes. The wizard prompts you to open a php page first.
Jonas
Databridge crash
Data Bridge crashes all the time when I create custom pages from my own database. It comes up a long crash-report in the computer each time.
I am using Dreamweaver CS5.5 on mac os 10.8.2.
Data Bridge 1.1.3.
I use localhost testing server MAMP 2.0.5. I can write to the database from a form I made in the form builder. So the connection works.
I have reinstalled the entire Adobe CS5.5 and updated related software to the latest version.
I have reinstalled WebAssist Free Tools 1.0.2, Design Extender 1.1.1, Ecart 5.0.6 and Data Bridge 1.1.3 without change.
When I create detail, search and results page, it crashes dreamweaver.
Jonas
It works now
Now it works as it should for some reason I do not understand. Hope it stays that way.
paulstock307210
I too am experiencing crashing issues with Data Bridge 1.1.4 on Mac OSX 10.8.4 using CS6, very similar to the above described (crashing at random intervals during the wizard stage). Page is PHP and already saved. Uninstalled all plugins, dropped the cache, restated DW and closed it, installed eCart and then Data Bridge however the issue persists. Any advice most welcome.
If you are using your own table can you provide a dump of the database structure so i can try to recreate the problem?
Some things to try:
Restart the computer, Dreamweaver can sometimes consume memory and not put it back. If it has been running for a while, it can get to a state where there is limited free memory.
Close the Files panel and Server Behaviors panel before starting the Create pages wizard.
Disable the preview. Go to WebAssist -> Preferences. In the preview section set the option to disable the preview.
after setting one of the pages and clicking the ok button, wait a few for the UI to stop processing before making the next selection.
