Orders are not being sent to Database
Thread begun 10/02/2012 4:28 pm by reiter303441179 | Last modified 10/04/2012 11:07 am by reiter303441179 | 4398 views | 7 replies |
reiter303441179
I'm using the supplied database with modifications from WebAssist but have not modified the orders tables and orders are not being sent to the database. I saw a thread mention that there was a thread explaining this problem but have not been able to locate it. Attached is the code for the confirm page.
in future, please don't post a PDF version of the page, compress the original PHP page to a zip archive to attach it to your post.
For the problem, try changing the trigger for the store order summary and details behaviors from Current Page Submit to Button: Submit_order pressed
reiter303441179
Jason that didn't work but could this be part of the problem?
"Warning: require_once(/public_html/pear/Log/mail.php) [function.require-once]: failed to open stream: No such file or directory in /home1/barrelr2/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Fatal error: require_once() [function.require]: Failed opening required '/public_html/pear/Log/mail.php' (include_path='.:/usr/lib64/php:/usr/lib/php:/usr/share/pear') in /home1/barrelr2/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113"
Could it be due to an error on the emailing receipt which causes it to not send the receipt nor the info to the database due to the database inclusion is after the emailing? However, the credit card is being processed.
So, to sum it up I guess I have two problems; the database one and an emailing one.
Attached is a zip of the confirm page
yeah, the error on sending the email is preventing the order from being stored in the database.
the error means that the Path to pear that you are using in the Universal Email settings is not correct.
contact your host for help in finding the correct path to pear.
reiter303441179
Jason, it's still not working I'm still getting the same error as above but it ends with Mail.php. Why is it looking in the "/home1/barrelr2/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php" in reference to the fatal error. Is there something else wrong in my code?
Here is the newest error:
"Warning: require_once(/home1/barrelr2/phpMail.php) [function.require-once]: failed to open stream: No such file or directory in /home1/barrelr2/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Fatal error: require_once() [function.require]: Failed opening required '/home1/barrelr2/phpMail.php' (include_path='.:/usr/lib64/php:/usr/lib/php:/usr/share/pear') in /home1/barrelr2/public_html/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113"
I've check and the Mail.php is in this php folder
reiter303441179
If the path is set to /home1/barrelr2/php you get the above error, if the path is changed to /home1/barrelr2/php/ the confirm page continues to load for a while then finally goes to the success page but never emails the receipt. Could the email not be sending due to being in testing mode?
no, it's not that it is in test mode, it is that the SMTP Server is not relaying the email message.
double check that you have entered the correct SMTP server address, and that you have entered the correct username and password to access it.
double check the From Email address to make sure that you have entered a valid email address for your domain.
make sure that your test orders do not use the same email address as used for the From address, most SMTP Server will refuse to relay emails where the from and to addresses are the same.
if you continue to have a problem. add the following code to the success page before the </body> tag:
<pre><?php @session_start(); var_dump($_SESSION); ?></pre>
this will output the contents of the session to the page, and will include a email sent success or failure if the email was sent to the SMTP server successfully, you will need to contact the host to look into the SMTP server error logs to determine why the email is not being relayed.
reiter303441179
Thanks Jason, I'll get on that and see what I find.
