Product Options in the Products Result page
Thread began 9/28/2012 2:33 pm by dDog | Last modified 10/01/2012 8:30 am by Jason Byrnes | 964 views | 1 replies |
dDog
Hello,
I'm attempting to display unique product options on each product on the products_Results.php page.
I borrowed the recordset code for rsOptions from the product_Details.php page which filters the ProductID by the URL. Obviously that will not work with multiple products at once. What solution should I use for the product_Results.php page?
Help is always greatly appreciated.
products_Results.zip
Product options on the results page is problematic. It requires a good understanding of PHP code and recordsets to be able to accomplish.
your product results page will use a recordset and recordset loop to populate the page with products.
To look up the options, you need another recordset that queries the product options table, and uses the product ID from the products recordset as a filter. Dreamweaver will add this recordset ion the head of the page, you will need to manually move the recordset code so that it is inside the products recordset loop.
