Convert DW template to Design Extender - making updates to template
Thread begun 9/26/2012 5:07 pm by sandy170299 | Last modified 9/27/2012 11:37 am by sandy170299 | 1331 views | 2 replies |
sandy170299
I followed the tutorial on converting a DW template to Design Extender framework, but now I am unable to edit the template to create a new editable region. I'm sure I missed a step, but I'm just not sure what that step is...??? Thank you!
the framework builder theme wont automatically update when you add new Editable regions to the template. The template structure of editable regions should be finalized before you convert the template to a theme. If you have to edit the template edible region structure, you will need to delete the theme file in the templates/Themes folder, then recreate the theme from the template.
sandy170299
Jason, let me see if I understand this correctly. If I create a template, for example, named insidepages.dwt.php, create pages based on this template, then do the following:
Webassist >> Framework Builder >> Themes >> Create Theme, it will mean that I will no longer be able to create new editable regions in my template that the theme was based on? Is this correct?
What I need to do at this point is delete the framework files from the Themes folder, and then I will be able to edit my template again? Then I would need to recreate the theme?
Is this correct? Hope I'm making sense!
