Inserting Two Records from the Same Form
Thread begun 9/21/2012 11:12 pm by salaroche | Last modified 9/24/2012 10:24 pm by salaroche | 2688 views | 4 replies |
salaroche
Hi:
I have an Insert Record form/behavior that is working perfectly well. However, I would now like to populate a second table using a second recordset and a second insert-record behavior.
The problem I think I'm having is that when I press the "Submit" button, DW inserts the first record only and doesn't insert the second one. I've tried using a different trigger for the second record insertion, but I haven't found an appropriate one.
Any suggestions?
Thank you for your attention
gavind
Hi. You might find this useful.
da_insert_multiple_records_sr.pdf
@salaroche: make sure that the first insert record behavior is not set to redirect to another page, this will cause the redirect to happen before the second record can be inserted.
@gavind: i dont think the Insert Multiple records tutorial is quite the right approach for this instance. salaroche is asking about inserting to two tables, not multiple records to the same table.
salaroche
Jason:
Thank you for your reply. I'll try your suggestion As soon as I have a moment. Thanks to Gavin for his input.
Thank you for your attention.
salaroche
Jason:
I just tried your solution and it works perfectly well.
Many Thanks
