2 instances of Current State showing in menu
Thread begun 9/11/2012 6:41 am by davegw | Last modified 9/11/2012 12:22 pm by davegw | 1158 views | 2 replies |
davegw
I'm using CSS Menu Writer with DW CS5.5 for a horizontal menu (top level only) with the menu item highlighted for the current page. Everything works fine until the browser back button is used. The previous page's menu button lights up as it should, but the menu button for the page moved away from is still in the current state, so now 2 buttons are highlighted. Same behavior with the browser forward button. Go back a few pages and always 2 menu items highlighted.
Both Firefox 15 & IE9 are affected, Chrome & Safari are behaving.
I've put 3 meta tags on each page:
<meta http-equiv="Cache-Control" content="no-cache" />
<meta http-equiv="Pragma" content="no-cache" />
<meta http-equiv="expires" content="0" />
which I thought would eliminate any cache problems with the Back button, but no effect.
I tried various options for Background & Borders in the Design tab, but no change.
I'm also a bit confused about how the Background: <a> , <span> & <li> options work.
Any suggestions?
do you have a link where i can see the problem to investigate please.
davegw
Hi Jason
www.chelseagardenandhome.co.za
The menu is wrapped in a containing div with width of 700px so that the menu items fit on 2 lines. Also I notice there is a slight delay in displaying the menu current state, but some of the pages are quite image heavy so that's probably why.
this is really a limitation to the back button.
the back button in most browsers triggers the javascript history.back() function. the problem is that it loads the previous page without first unloading the current page. so basically both pages are loaded to the browser now.
not really much can be done about it, it is a browser limitation
