Cannot add eCart object
Thread begun 8/24/2012 4:28 am by marovios@yahoo.com | Last modified 8/27/2012 7:38 am by marovios@yahoo.com | 2460 views | 4 replies |
marovios@yahoo.com
For some reason, since I installed Data Bridge and Design Extender, I cannot use eCart 5.0.6 anymore. If I open a page with an existing eCart and follow the checkout wizard nothing get added at the end, the eCart panel opens and stays there. If I start all over on a fresh site I don't even have the option to add the eCart because the icon appears disabled.
I have read only one issue like mine on this forum and that person had some weird symbols on the DW site structure, that's not my case though. I also installed WAMP server (I'm using EasyPHP) to try an alternative, that software made the installation on my hard disk c:/wamp and still nothing. So it doesn't seem to be a bad path symbol on the site path.
On more thing that might troubleshoot this. I removed the eCart extension. Then deleted the cache dat file and opened up DW CS6 (happens the same with my DW CS4). Then closed it again. Then I remove the cache file again. I then proceed to install the eCart 5.0.6 extension (same version I had before).
When I open DW CS6 I see the "add eCart object" icon enabled. Great, so I click on it and it asks for activation. Here comes the weird part again. I activate it and I see it says eCart version: undefined. Then the "add to eCart object" gets disabled and I see a legend on the same eCart floating panel that reads "to enable eCart, please select the PHP server model" which is obviously already selected. Anyway, I thought this might help with troubleshooting.
What can I do?. Thanks.
marovios@yahoo.com
This post has been deleted.
What is the build number of Dreamweaver?
Have you tried installing the 12.0.1 update to Dreamweaver CS6 available for download from adobe?
dreamweaver-cs6-update-12-0-1.html
marovios@yahoo.com
Hi Jason, thanks for replying.
I have the same issue on both Dreamweavers, one is Dreamweaver 10.0 Build 4117 (CS4) and the other is Dreamweaver 12.0 5808 (CS6).
I have not tried upgrading to 12.0.1 but still, why is not working on CS4?
If I copy an eCart from my previous sites then I can edit it but as soon as I try to run the checkout wizard nothing happens. I enter in all the info on every step, and then click on Finish, nothing happens.
Sometimes running the checkout wizard will need a slight kick to get going, try clicking inside the eCart object window after starting the checkout wizard. I have found this to trigger the checkout wizard to start running if it stalls.
marovios@yahoo.com
Yes, sounds like is what it takes to make it work in both DW CS4 and CS6. Still don't like the fact that in DW CS6 the eCart version reads "undefined". Hope you can fix this small issue on future releases. Thanks much for your help.
