API Key
Thread began 8/11/2012 3:01 am by J7HNW | Last modified 8/13/2012 8:11 am by Jason Byrnes | 840 views | 1 replies |
J7HNW
API Key
I canot find anywehere where I can generate a new API key. I see this is now deprectaed for this app in a warning message here
See attached grab for error message
I turned on V2 as per another thread and generated a key but i get an error message ?
Please advise
the area that you use to enable the V2 map API is the area where you can generate the API key, make sure that the API key you generated here is the one that you are using Pro Maps, if it is the one you have turned on the V2 api for, you should be getting that error message.
